MD30C
MD30C
Postby huajui » Mon Jul 18, 2016 6:28 pm
I am planning to do a electric scooter project using this MD30C controller. Here are some of my question before i purchase from Cytron:
1. Can i use the potentiometer to control the motor speed of the 24V 350watt DC motor that i purchase from Cytron?
2. if the potentiometer can be use to control the motor speed, will it run smoothly?
3. I use 2 12V car battery as my power supply, should i solder the wire to the pad at the bottom layer of the MD30C?
4. The 24V 350W motor that i purchase from Cytron also need to solder to the pad at the bottom layer of the MD30C?
5. The external potentiometer that i use also need to be soldered?
huajui
Re: MD30C
Postby Idris » Tue Jul 19, 2016 5:10 pm
Hi huajui,
huajui WROTE:1. Can i use the potentiometer to control the motor speed of the 24V 350watt DC motor that i purchase from Cytron?
Yes.
huajui WROTE:2. if the potentiometer can be use to control the motor speed, will it run smoothly?
PWM applied to the motor is proportional to the potentiometer resistance.
huajui WROTE:3. I use 2 12V car battery as my power supply, should i solder the wire to the pad at the bottom layer of the MD30C?
Solder is recommended for high current. Please refer to User's Manual under Hardware Installation.
huajui WROTE:4. The 24V 350W motor that i purchase from Cytron also need to solder to the pad at the bottom layer of the MD30C?
huajui WROTE:5. The external potentiometer that i use also need to be soldered?
You need to connect to the corresponding pad. Please refer to User's Manual under Hardware Installation.
MD10C User's Manual.
