MD30C power supply - regenerative energy
Postby pecker88 » Wed Jan 25, 2017 9:59 pm
I ordered a MD30C to use with a 12V 30A gear motor. I do not want to use a battery to power the motor, I would rather use a MegaWatt 36 Amp 12 Volt 13.8V DC Regulated Power Supply.
Can anyone help me design a simple switched resistor or capacitor bank to use inline with the driver pwr input to absorbs the regenerative energy of the motor when it's turned off? The motor will control a 30 ft long rollup curtain for a greenhouse, max of 40 RPM. I really don't think I'll have that much regen, but I have no idea how to quantify it.
Any ideas would help, I really don't want to spend $120 on a 12v battery simply for regen purposes...
thanks!
pecker88
Re: MD30C power supply - regenerative energy
Postby Fearthetrees » Fri Mar 02, 2018 3:00 am
I'm looking into a similar situation using a MDD10A and a DC/DC converter (I6A4W020A033V-001-R) so if I find anything/come up with a solution I'll make sure to let you know.
Good luck (if you're still working on this) :D
-Chris
Fearthetrees
