Interface G15 Driver GD02 R2.0 with myRio
Postby Ravinath » Thu Dec 21, 2017 2:32 am
hye..im having trouble in doing interface between g15 driver (GD02rev2.0) with myrio..how to make the g15 cube servo run only by using myrio?if we want to run the g15 motor using ARDUINO we need to set its Id in the code.So, if I want to run the g15 servo motor using myRio, how to run it by LABVIEW?? kindly needs your help. :(
Ravinath
Re: Interface G15 Driver GD02 R2.0 with myRio
Postby ober » Tue Dec 26, 2017 9:02 am
Well, I am not familiar with LabView, but every programming language should be able to send serial data and package the data up. Check the G15 serial data format and package it up accordingly in LabView.
