MD30C external switches
Postby liteace » Thu Dec 28, 2017 6:13 am
The MD30C, I see on the PDF your using switches like this:
Do these type of switches need to be pressed and held for the motor to run ?
Could I use a switch like this:
So when the controller is powered up and the switch is set the motor will run in CW or CCW
Thanks
liteace
Re: MD30C external switches
Postby ober » Fri Dec 29, 2017 6:52 am
Yes, you can use the toggle switch as you show.
