Ultrasonic sensor using mb1013 and sn lv ultrasonic sensor
Postby vidya shini » Thu Feb 22, 2018 5:32 pm
Ultrasonic sensor using mb1013 and high Range
sn lv ultrasonic sensor can i Get the Circuit and Code to detect the difference height measurement In tank using sk40c...
vidya shini
Re: Ultrasonic sensor using mb1013 and sn lv ultrasonic sens
Postby derrick » Thu Mar 29, 2018 5:24 am
Circuit can be found in this tutorial. You can edit the code on getting distance information from sensor which is in the tutorial as well to detect height difference
https://tutorial.cytron.io/2011/08/09/project-6-%E2%80%93-analog-sensor-range-using-ultrasonic-range-finder/
derrick
