SmartDriveDuo-30 ground connection
Postby jallen » Thu Nov 08, 2018 9:03 pm
Hello.
Can I connect the SmartDriveDuo-30 battery negative terminal to the SmartDriveDuo-30 GND connections?
I am using the motor battery to regulate to 5V for my controller.
The battery negative connection will go through the 5V regulator to the controller and back to the SmartDriveDuo-30 GND connections.
Thanks
jallen
Re: SmartDriveDuo-30 ground connection
Postby ober » Fri Nov 09, 2018 9:10 am
Yes, you can. The negative terminal is common GND.
