connect 2A Motor Driver Shield to Arduino Mega
Postby alex1 » Thu Jun 20, 2019 4:27 am
Hi
I tried to connect 2A Motor Driver Shield to Arduino Mega through the wires, but it is not working.
4 jumpers are connected to the Signed Magnitude pins and I connect the 4 pins of Arduino mega (5,4,6,7) to the Signed Magnitude pins and I change VIN pin to the PWERIN pin, but it is not working. how can I overcome this problem, I use samples code from following URL
https://github.com/CytronTechnologies/C ... eld2AMotor
alex1
Re: connect 2A Motor Driver Shield to Arduino Mega
Postby ober » Thu Jun 20, 2019 4:56 am
Mind showing the actual hardware wiring and setup? Have you connected the 5V and GND?
