MDDS30 NC pin on PWM and Serial connections
Postby john sampson » Mon Jul 29, 2019 10:55 am
I have searched and cannot find any mention of the NC pins in the documentation.
I assume this pin is labeled NC for not connected. Is that the case?
Should i just leave it floating in PWM or Serial mode?
Is it a 5v connection?
Is there a reason the included grove connectors have a red wire for this pin?
Thanks-
john sampson
Re: MDDS30 NC pin on PWM and Serial connections
Postby ober » Tue Jul 30, 2019 6:16 am
Hi, I believe you are referring to the "NC" on Grove connector.
Yup, NC refer to "Not Connected".
We will update the User's Manual to indicate that.
