MDDS30 as speed controller for go kart
Postby BlueCharisma » Mon Aug 10, 2020 3:45 am
I was wondering if it was possible to use the MDDS30 as a speed controller for my kids power wheel. I see analog mode could be used with a hall effect throttle. From what i can tell the system auto brakes?
Basically is there a way I could set it up with variable gas and a brake pedals?
BlueCharisma
Re: MDDS30 as speed controller for go kart
Postby waiweng83 » Fri Aug 14, 2020 10:41 am
Although the MDDS30 can be used with hall effect throttle, but it doesn't support the extra brake pedal. The motor will be brake whenever the gas is let go.
waiweng83
