I have try to download the "PICDEM FSUSB User's Guide" in SK40C Useful Document but it display "The system cannot find the file specified".
How can I download it?
blank172 WROTE:I just bought SK40C and played around with it. I loaded the blinking led program from the Cytron site, however, the built-in LED1 and LED2 did not show any response when SW1 and SW2 are pressed. (FYI, LED1/LED2 blinked during the WRITE process so i assumed it is ok.)
Instead, I have to put LED from pins RB0 and RB1 to ground then pressed SW1 and SW2 switch on board (which are also RB1 and RB2[?]). The LEDs by default ON and when pressed the SW1 and SW2 it turn off.
ober WROTE:LED1 and LED2 blink during loading program because the programming signal is connected to these 2 LEDs.
Have you connect the crystal to SK40C? It should come with 20MHz Crystal.
ober WROTE:Are you using PIC16F877A? Because the sample source code is created based on this model.
The gnd pin is not connected to Crystal. At the back of SK40C User's Manual, the schematic of SK40C is being illustrated. Please refer there for more detail.
