aurora, what type of LCD you are using? I have personally grab a SK40C, new batch, checked the pin and even solder a LCD on it, load program and it works without problem.
Checked the pin assignment too, pin 5 from left (looking at the SK40C horizontally), that is R/W from LCD pin and it is grounded on SK40C which like shiyan said, the data send to LCD will be written to LCD, we will not be able to read from LCD.
and pin 6 from left is E for the LCD pin and it is connected to RB5 on SK40C.
Do let us know if you are using different type of LCD, so that we can think of some method to make the SK more flexible.
