noien WROTE:I do tick for the 5v and since the pickit2 already been showing this since yesterday.so I forget to tick it since it is a screen shot
I did the troubleshoot using the pickit2 troubleshoot.
The first one is to test the Vdd and Vss pin(pin11 and 12).I use a pin header and put in the socket but the multimeter show 0 although it is suppose to be 5V.I had tested with the Vpp pin pull down and just let it be.It will show 0 in the multimeter.
The second step is to test Vpp when the the troubleshoot program will produce 12V but in the end it is still 0V
Is the steps done by me is correct?
Thank you
noien, good that you know how to troubleshoot
you are connecting the UIC00B to UIC-S, correct? The easiest way to test the VDD is the LED on UIC-S. It should be activated when VDD is ON. Else, there might be problem on either UIC00B or UIC-S (maybe some short). As for Vpp, you can measure pin 1 on the 40 pin ZIF socket to GND. It should be 12V or around that voltage.
If still cannot get the expected result, please contact support again, we will arrange for product warranty to troubleshoot and repair it.
