Hi guys,
Been a while since I last check here, and there is dsPIC30F! Anyone try SKDS40A already? How is it? What was the reason you upgrade from PIC18F to dsPIC30F?
I'm attracted with the raw computing power, looks pretty good.
aurora WROTE:Hi guys,
robosang WROTE:Woh... Brian, you uses chipkit 32 already? How is the IDE and library? Nice!?
I never uses dsPIC nor PIC32, but been seeing some projects use those MCU. I think the Robot magazine from Cytron just share about SKds40, one of their project sharing is using dsPIC30F to be spectrum analyzer, not really gone through in details. You can download their magazine and take a look. I think the title is My 1st dsPIC project.
aurora WROTE:18F can do single-cycle multiplication, but only 8 x 8 bit. Division 16-cycle per instruction, as in 1 division query? This is nice.
Sound reproduction kind of hard. You need to do a lot raw computation as well? I'm using it for robotic, need to do a lot of multiplication, division, square root, trigo, etc. Any more useful tips?
aurora WROTE:Found a link for CORDIC [url=here]http://en.wikipedia.org/wiki/CORDIC[/url]. I read about CORDIC before and later abandon it. Can't remember why, I think not efficient for PIC (or too difficult). In the end I settle with lookup table, take up a lot of memory. Got to try that again.
I'm using a similar bit-shift method for division and square root, more efficient than C, but way more than 16 cycles.
aurora WROTE:Just received my SKDS40A and dspic30, I expect the learning curve wont be as easy, going to take some time before I transfer my code to 16-bit.
I need accuracy up to 4 decimal point for my asin function. CORDIC is for sin, not for asin, hence the look up table.
The code space for dspic is larger, how long does it take to download your code?
