Migration to dsPIC30F
Re: Migration to dsPIC30F
Postby sich » Wed Jul 06, 2011 12:47 am
Wow...this is enlightening! Good to see some PRO's talk in the forum :D
Postby Brian Griffin » Fri Oct 07, 2011 1:36 pm
Also, for migration to PIC16/18 to PIC24/30/33 has a bit of a learning curve, if you have to do it in ASM. The PIC24/30/33 has 16 'W' registers, compared to only one in the PIC16/18. Similarly, the AVR has 32 of the temporary registers, but they are handled in a different manner.
The PIC32 has a totally different world. Do not attempt "movlw" or "mov." - it won't work. For reference, check the MIPS assembly or the PIC32 programmer reference manual.
Things will get better in PIC32 in comparison to the others. Example, c = a + b: in PIC16/18F (30 + 20 = c in example)
PIC16/18F
CBLOCK 0x30
a
b
c
ENDC
.... ; more code here
movlw .30
movwf a
movlw .20
movwf b
movlw a
addwf b, c
(sorry, it's been a while since I do ASM, so pardon me for the errors)
Meanwhile, in PIC32:
... other code here
... ($t0 = c, $t1 = a, $t2 = b)
li $t1, 30
li $t2, 20
add $t0, $t1, $t2
Examples from : http://www.eecs.harvard.edu/~ellard/Courses/cs50-asm.pdf
You can see why PIC32 'adds' so easily. Despite being exposed to some of the PIC32 instruction sets for a few minutes, I can guess the ADD instruction which is quite readable, even in untrained eye.
And of course, delays may be easy. It's all 32-bits per register. It's up to one to improvise it, but I leave it to the readers' imagination. :)
