How to use PICKIT2 with UIC-S
Postby engkiang » Wed Aug 17, 2011 2:36 pm
Dear Sir/Madam,
I'm a entry level in PIC hardware and software. I have PICKIT2 and want to use the UIC-S to program the PIC microcontroller. I had searched several product in cytron and another adaptor was found is UIC-A.
How to link the PICKIT2 with UIC-A in order it can program the PIC microcontroller using UIC-S. Any graphical diagram or schematic to show the connection?
Thanks. :)
engkiang
Re: How to use PICKIT2 with UIC-S
Postby hyng » Thu Aug 18, 2011 3:37 pm
Yes, you can connect PICKIT2 with UIC-S via UIC-A. You can refer to the 2nd photo in UIC-A UM page 4 for the connection. You just replace the SK40C with UIC-S. However, you need the rainbow cable for the connection from UIC-A to UIC-S. The rainbow cable is not included in the UIC-A package.
Postby engkiang » Fri Aug 19, 2011 11:04 am
Hi hyng,
Thanks for the respond. How many devices that I able to program if using this configuration. Do you have the list of supported devices?
engkiang
Postby hyng » Fri Aug 19, 2011 4:09 pm
What devices that you mean? You mean PIC micrcontroller? It depends on the PICkit2.
UIC-A is just a adapter. BTW If you wonder where to get the rainbow cable.. this is the link
http://www.cytron.com.my/viewProduct.php?pcode=WR-UIC&name=UIC00A%20Cable%20Only
Postby engkiang » Mon Aug 22, 2011 4:16 pm
Hi hyng,
What I mean is PIC microcontroller family that supported with this kind of configuration. This type of configuration can support PIC range like 10F, 12F, 16F, 18F etc.
engkiang
