Hi, currently i am using ICD3 connect with SK40C, but facing problem "the target device not detected" in MPLAB IDE when i want to load program into PIC16. I made the converter from RJ-11 to 10 way header pin myself. The reference signal is almost same with UIC00A/B ICSP programmer right?
Refer to UIC-A manual page 2 and 3, from the schematic of ICD3 and SK40C,i made the below signal equality:-
SK40C ICD3
Pin 3(MCLR) --> Pin 1(MCLR/Vpp)
Pin 4(GND) --> Pin 3(GND)
Pin 5(PGC) --> Pin 5(PGC)
Pin 7(PGD) --> Pin 4(PGD)
Pin 8(VDD) --> Pin 2(VDD)
Pin 9(AUX) --> Pin 6(AUX)
After connect all the wire,the MPLAB software said that "Target Devide is not found/detected". is there any posibilities that SK40C failure?
and by the way when i refer to the SK40C user manual, the 8th pin and 9th pin from 10 way header does not poses any connection, so i need to connect the VDD from board to Pin 8 myself? Upon connected, the problem still exist. Pin 9 i understand is the LVP signal which not very important in this case.
i am confusing that VDD signal need to connect from SK40C to ICD3?
