40 Pins dsPIC Start-Up Kit
Postby ray_ars » Sat Dec 10, 2011 8:09 pm
I recently bought the 40pins dsPIC Start-Up Kit. With this kit I enjoyed the sample program provided in MPLAB C30 language. It worked well & begin modifying for additional functions. However I am stuck with the PWM. I need help on how to initialize the PWM functions & how to use them using MPLAB C30 compiler. Any sample code for PWM that uses MPLAB C30 would be a great help. By the way my target project is a light dimmer only that will use PWM as a means of control & I am using DSPIC30F4011.
ray_ars
Re: 40 Pins dsPIC Start-Up Kit
Postby zhenning » Sat Dec 10, 2011 8:22 pm
Look into MPLAB C30 installation folder. There should be quite a number of sample programs in it.
zhenning
Postby ray_ars » Sat Dec 10, 2011 8:37 pm
zhenning WROTE:Look into MPLAB C30 installation folder. There should be quite a number of sample programs in it.
:idea: That would do, thanks for the advice!
ray_ars
