voltage regulator for SK40C
Postby kcyong » Fri Feb 10, 2012 10:25 am
Recently I buy a SK40C and play around with it. I didn't realize my circuit have short circuit but i still connect it with SK40C. And after a few second, smoke come out from SK40C.
Is the voltage regulator in SK40C burn out? i measure the output voltage for the voltage regulator is 3.24V. So i plan to change the voltage regulator. Can i change it with voltage regulator 78L05? Which type of voltage regulator suitable for replace the voltage regulator in SK40C?
thank...
kcyong
Re: voltage regulator for SK40C
Postby hyng » Fri Feb 10, 2012 10:45 am
You can get one of this regulator to replace the spoilt regulator.
http://my.element14.com/texas-instruments/ua78m05cdcy/ic-linear-volt-regulator-5v-sot/dp/1575761?Ntt=1575761
Anyway, you can always send back to Cytron for warranty if the SK40C is still under warranty. Fill in the support form under that support tab. http://www.cytron.com.my/support.php
Postby kcyong » Fri Feb 10, 2012 3:10 pm
thank you..can i ask how can i check is the SK40C still under warranty? And the SK40C i buy from shop, so the SK40C still available for warranty?
kcyong
Postby hyng » Fri Feb 10, 2012 4:20 pm
Warranty is valid for 6 months from the purchase date. Anyway, T&C apply. You just fill in the form and the support team will advise you.
