by chaos64 » Tue Apr 03, 2012 9:48 am
Okay since we thought at first it was the soldering on the LCD that was our problem, my friend took it to try and fix, but now since I realize this header we used is the wrong type, my first question is:
1. If I plug the LCD pins into a breadboard and use jumpers to connect to the Turn-Pin header, will that make sufficient contact to communicate properly to my LCD assuming the soldering job on the LCD pins is good enough? and
2. Should I try and de-solder the Turn-Pin header from the board and solder the LCD pins directly in its place on the SK40C?
I'm still not sure why this header would not work fine with the LCD pins, it plugged in fine but the pins didn't seem to go in all the way, I suppose that's the issue? I mean it plugged in fine meaning that it isn't difficult to insert or take out, it just seemed to not go in deep enough. The LCD backlight pin always worked, if the LCD backlight jumper on the SK40C board was plugged in using a jumper, the LCD backlight was always on when the board is powered. This is with the LCD plugged into the Turn-Pin header that you all believe is the cause of my problem. So before I try and desolder this Turn-Pin header, I'd like to know why the backlight pin and obviously Vdd worked as well since the backlight is good work but communicating to the LCD didn't work with the sample program. Please help.
