Hello, may I know if cytron supply an equipment or component that is required to build a USB Flash drive? I found 4G USB Flash drive but it look like it stop manufacturing.
If you are trying to create a flash drive using microcontroller and SD card, you just need this microSD breakout board in term of hardware. You can find example code and connection for PIC32 and mbed in the same page too.
