Hi, I try download SKPIC32 with chipkit bootloader get from this page chipKIT UNO.
But, why chipkit software can't program into it. Is this SKPIC32 can use chipkit bootloader?
sich WROTE:Hi shahrul, SKPIC32 is using PIC32MX795F512L, while chipKIT Uno32 has PIC32MX320F128H onboard. So they are both using different PIC32 chip. Perhaps chipKIT Max32's bootloader firmware will work but I've never tried it.
sich WROTE:I'll give it a try when I'm free. May be chipKIT needs sth else for the bootloader to work.
Thanks for choosing SKPIC32...
Since some of you are using it, please give some feedback about this product k? Let us know your user experience, good or bad things about the product, improvement needed and etc are all welcomed.
Some info...We noticed that we should disconnect the USBID/RF3 pin from USB mini connector by default, in order to use it as I/O. You will need to connect it with a jumper to use the USB-OTG function. We'll modify that in next PCB batch.
