why the led is not blink?
Postby cheelip » Sat Jun 02, 2012 3:57 am
may i know does connection of UIC00B programmer===>SK40C====>PIC16f876a or PIC16f887 having any problem or not ? because i wanna to test the function of the pic by blinking a led with simple program in C and asm altough the PIC2kit window showing some data in program memory and i also export the data from programmed pic in PIC2kit window and is all right but still unable blinking a led at all (before this i able am using the SK40C with pic16f876a in DIY set and is OK but i don't know what is the problem on this time),can someone let me know what is the problem because i wanna start to do my final year project , thanks for replying.....
cheelip
Re: why the led is not blink?
Postby sich » Sun Jun 03, 2012 12:36 am
PICkit 2 software shows "Programming Successful"? With your explanation, it's very little that we can do to help...
Postby cheelip » Sun Jun 03, 2012 9:30 pm
sich WROTE:PICkit 2 software shows "Programming Successful"? With your explanation, it's very little that we can do to help...
I will try my best to find the cause, thank for replying :)
cheelip
Postby hyng » Mon Jun 04, 2012 9:18 am
SK40C is 40pins starter kit while 16F876A is only 28pins. Are you referring to 16F877A?
