SK40C + PIC16F887 + UC00A problem
Postby monky91 » Mon Jun 18, 2012 3:13 pm
Hi guys, newbie here, do you guys have any idea how to troubleshoot my problem.
I have all the combination above, but my hyperterminal doesn't show anything, I follow exactly the same thing in http://tutorial.cytron.com.my/2011/08/1 ... -computer/
but no luck it is working, hyperterminal just wont get any signal, the RX and TX LEDs in UC00A blink once in a while, but there is no result in Hyperterminal.
monky91
Re: SK40C + PIC16F887 + UC00A problem
Postby robosang » Mon Jun 18, 2012 5:55 pm
photo of your hardware will be helpful.
Postby monky91 » Mon Jun 18, 2012 6:43 pm
robosang WROTE:photo of your hardware will be helpful.
Hi robosang, thanks for the prompt reply. I din change anything, its the original SK40C from cytron, PIC16F887 from cytron, and UC00A USB Uart Converter from cytron.
What I did is, burn the sample code from cytron tutorial (Project 13) and try to connect through Hyperterminal. (Connect via UC00A only, without power supply)
Why I didn't connect to power supply is because my friend spoilt a SK40C because the voltage is too high (I suppose)
monky91
