Error in programming Project 6 (ultrasonic range finder)
Postby yeosteven » Wed Jul 04, 2012 1:03 pm
When I follow the source code given for project 6 ultra sonic range finder
i got error in adc.c...the code is
* This file provides the functions for the ADC module
* Cytron Technologies Sdn. Bhd.
// This file is written for PIC16F887, if other model of PIC is uses, please modify accordingly
#include <htc.h>
#include "system.h"
#include "adc.h"
* PUBLIC FUNCTION: adc_initialize
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* Initialize the ADC module.
void adc_initialize(void)
   // A/D Conversion Clock = FOSC/32.
   ADCS1 = 1;
   ADCS0 = 0;
   // Set AN as analog pin
   ANS0 = 1;
   // Configure the result to be right justified, will take as 10-bit ADC
   ADFM = 1;
   VCFG1 = 0;
   VCFG0 = 0;
   // Turn Off ADC module by default
   ADON = 0;
* PUBLIC FUNCTION: adc_on
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* Activate ADC module
void adc_on(void)
   // Turn On ADC module
   ADON = 1;
* PUBLIC FUNCTION: adc_off
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* Deactivate ADC module
void adc_off(void)
   // Turn Off ADC module, to save power
   ADON = 0;
* PUBLIC FUNCTION: ui_adc_read
* PARAMETERS:
* ~ void
* RETURN:
* ~ The ADC result in 16-bit
* DESCRIPTIONS:
* Convert and read the result of the ADC from ANO.
unsigned int ui_adc_read(void)
   unsigned int pot = 0;
   // Select the ADC channel on AN0 for SK40C
   CHS2 = 0;
   CHS1 = 0;
   CHS0 = 0;
   // Delay 1mS to fully charge the holding capacitor in the ADC module.
   __delay_ms(1);
   // Start the conversion and wait for it to complete.
   GODONE = 1;
   while (GODONE == 1);
   // Return 10-bit ADC result.
   pot = (unsigned int)ADRESH << 8;
   pot = pot + ADRESL;
   return pot;
but I got error with this :
Build C:\Users\Yeo\Desktop\ETP\Project_6\Project_6 for device 16F887
Using driver C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe
Make: The target "C:\Users\Yeo\Desktop\ETP\Project_6\adc.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Yeo\Desktop\ETP\Project_6\adc.c -q --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [192] C:\Users\Yeo\Desktop\ETP\Project_6\adc.c; 117.1 undefined identifier "GODONE"
Make: The target "C:\Users\Yeo\Desktop\ETP\Project_6\Project_6.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Yeo\Desktop\ETP\Project_6\Project_6.c -q --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Make: The target "C:\Users\Yeo\Desktop\ETP\Project_6\lcd.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Yeo\Desktop\ETP\Project_6\lcd.c -q --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Make: The target "C:\Users\Yeo\Desktop\ETP\Project_6\uart.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Yeo\Desktop\ETP\Project_6\uart.c -q --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
********** Build failed! **********
anyone can guild me with this?? appreciate ^^
yeosteven
Re: Error in programming Project 6 (ultrasonic range finder)
Postby shahrul » Wed Jul 04, 2012 1:24 pm
Change GODONE into GO
Example Peripheral see here.
Postby robosang » Wed Jul 04, 2012 3:11 pm
well, this is due to different version of HI-TECH Compiler. As far as I know, v9.80 and v9.82 have header file generate with different register name. In this case, the GODONE is one version and GO_DONE should be another version. You can try what being suggested by shahrul, try ADGO if it does not solved the problem.
This also cause the configuration bits problem. I think I saw thread discuss about this before, anyway you should be able to to solve it from the suggestion given :)
Postby yeosteven » Wed Jul 04, 2012 4:38 pm
Thnks alot~!!!will try it soon!!haha..appreciate!!
yeosteven
Postby zhenning » Thu Jul 05, 2012 11:57 am
robosang WROTE:well, this is due to different version of HI-TECH Compiler. As far as I know, v9.80 and v9.82 have header file generate with different register name. In this case, the GODONE is one version and GO_DONE should be another version. You can try what being suggested by shahrul, try ADGO if it does not solved the problem.
Yup. Not sure why they want to change the names from one version to another. They also change their configuration format:
__CONFIG(MCLRE_OFF & PWRTE_ON & WDTE_OFF & FOSC_INTRCIO);
zhenning
Postby yeosteven » Wed Jul 11, 2012 11:01 am
Guys...i have change the code and it can be build already...however my display shows distance of 503.....no matter how I move the sensor...the display still show 503?? What is happening??
yeosteven
Postby yeosteven » Wed Jul 11, 2012 11:09 am
I change the cinfig to this
and i get build failed?? how come?
I;m so noob in this~~
yeosteven
Postby yonghui » Wed Jul 11, 2012 1:06 pm
u can refer the the compiler reports error to know what are the errors. if its parameter definition errors, it will shows something undefined, or redefined. etc. then u will know which to correct.
Postby yeosteven » Wed Jul 11, 2012 1:22 pm
I got this error and i do not understand...can help??
Error [194] C:\Users\Yeo\Desktop\ETP\Project_6\Project_6.c; 20.11 ")" expected
yeosteven
Postby yeosteven » Thu Jul 12, 2012 7:09 pm
I manage to find the problem with the error there as I change the ___ to __
howeever i got another problem now....my code is
//   Author            : CYTRON TECHNOLOGIES SDN BHD
//   Project            : SK40C sample code for PIC16F887
//   Project description   : Analog Sensor: Range using Ultrasonic Range Finder
//                    3 mode : (1: Analog)
//                           (2: PWM   )
//                           (3: UART  )
//   include
#include <htc.h>
#include "lcd.h"
#include "adc.h"
#include "system.h"
#include "uart.h"
//   Configuration
//   global variable
unsigned int To=0,T=0,TH=0;
unsigned char data[6] = {0};
//  Interrrupt Subroutine
   if (T0IF)                        // TMR0 is overflow
      T0IF = 0;                      // clear flag bit
      To +=0x100;                     // count number of TMR0 overflow ( make it to 16bit TMR)
   if(RBIF)                        // there is change bit on RB4-RB7
      RBIF = 0;                     //                                           ____
      if (PWM_IN)                     // PWM_IN(RB2) is 1 mean is rising form 0  __|
         TMR0 = 0;                  // clear all counter involved, start new count for period of RB4 high
         To = 0;
                                 //                                 ___
      else TH = TMR0 + To;            // PWM_IN(RB2) is 0 mean is falling form 1       |_____  // save TH, RB4 high period
//   main function
void main(void)
unsigned char mode = 1;
   PORTA = 0;                     // Clear Port
   PORTB = 0;
   PORTC = 0;
   PORTD = 0;
   TRISA = 0b11111111;               // set PORTA as INPUT
   TRISB = 0b00000111;               // set PORTB<7:3> as OUTPUT , PORTB<2:0> as INPUT
   TRISC = 0b10000000;
   TRISD = 0b00000000;               // set PORTD as output
   ANSELH = 0;                   // SET PORTB as DIGITAL I/O for PIC16F887
   WPUB = 1;                     // PORTB Weak Pull Up enable
   // Interupt on change
   IOCB0 = 0;
   IOCB1 = 0;
   IOCB2 = 1;                     // when PORTB.2 detect change will interrupt
   IOCB3 = 0;
   IOCB4 = 0;
   IOCB5 = 0;
   IOCB6 = 0;
   IOCB7 = 0;
   RBIE = 1;                     // PORTB Change Interrupt Enable bit
   // TMR 0 configuation
   T0CS = 0;
   PSA = 0;
   PS2 = 1;                     // prescale 1:256
   PS1 = 1;
   PS0 = 1;
   T0IE = 1;                     // TMR0 Interrupt
   TMR0 = 0;
   GIE = 1;                     // Global Intterupt enable
   PEIE = 1;                     // Peripheral Interrupt enable
   lcd_initialize();               // Initialise LCD
   adc_initialize();               // Initialise ADC
   uart_initialize();               // Initialise UART
   TX == 1;                     // ON Transmit pin (refer Maxbotix EZ1 Ultrasonic datasheet)
   lcd_home();
   lcd_putstr("Dist:");
   lcd_goto(0x0B);
   lcd_putstr("inch");
while (1)
   switch(mode)
   case 1:         lcd_2ndline();
               lcd_putstr("Analog");
               while (SW1 == 1)
                  unsigned int adc_value = 0;
                  unsigned int range_an = 0;
                  unsigned char j;
                  adc_on();
                  for(j = 0 ; j < 10 ; j++)                  // take analog result for 20 times
                     adc_value = adc_value + ui_adc_read();
                  adc_value = adc_value/10;                  // adc_value devide by 10 to get average result
                  range_an = adc_value/2;                     // max vslue adc_value = 2.55/5 *1024 - 1 =  522
                  lcd_goto(0x05);                           // max is 254 inch... 522/254 = ~2
                   lcd_bcd(3,range_an);                     // (1 to 6 inch) is readed as 6 inch (refer to ultrasonic datasheet)
               while (SW1 == 0);
               break;
   case 2:         lcd_2ndline();
               lcd_putstr("PWM   ");
               unsigned int range_pwm;
               while(SW1 == 1)
                  range_pwm = TH;                           // read TH from interrupt subroutine
                  lcd_goto(0x05);                           // each value = 256*4/20mhz = 51.2us, 1 inch = 147us
                  range_pwm = (range_pwm*100)/288;            // 147us/51.2us = 2.87
                  lcd_bcd(3,range_pwm);
               while (SW1 == 0);
               break;
   case 3:          lcd_2ndline();
               lcd_putstr("UART   ");
               unsigned int value,k,l = 0;
               while(SW1 == 1)
                  for (l=0 ; l<6 ; l++)
                     uc_uart_receive();                     //take value from UART subroutine
                     if(RCREG == 'R') data[k=0] = RCREG;         // check if start byte 'R' is met
                     if(data[0] == 'R') data[k++] = RCREG;      // save the data in data array
                     if (k>4) k = 4;                        // if the data array reached max, set the index to 4
                     lcd_goto(0x05);
                     send_lcd_data(1,data[1]);
                     send_lcd_data(1,data[2]);
                     send_lcd_data(1,data[3]);
      while (SW1 == 0);
      if (++mode > 3)             // if SW1 is press, increase the mode number until it is max and loop back
         mode = 1;
and i got this error...
Clean: Deleted file "C:\Users\Yeo\Desktop\ETP\Project_6\adc.p1".
Clean Warning: File "C:\Users\Yeo\Desktop\ETP\Project_6\Project_6.p1" doesn't exist.
Clean: Deleted file "C:\Users\Yeo\Desktop\ETP\Project_6\lcd.p1".
Clean: Deleted file "C:\Users\Yeo\Desktop\ETP\Project_6\uart.p1".
Clean: Done.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" -oProject_6.cof -mProject_6.map --summary=default,-psect,-class,+mem,-hex --output=default,-inhx032 adc.p1 Project_6.p1 lcd.p1 uart.p1 --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.83
Copyright (C) 2011 Microchip Technology Inc.
(1273) Omniscient Code Generation not available in Lite mode (warning)
Error [800] C:\Users\Yeo\AppData\Local\Temp\s4s4.; 45. undefined symbol "FOSC_INTRCIO"
how should I define this?? anyone help??
yeosteven
