- CODE: SELECT_ALL_CODE
// Author : CYTRON TECHNOLOGIES SDN BHD
// Project : SK40C sample code for PIC16F887
// Project description : Analog Sensor: Range using Ultrasonic Range Finder
// 3 mode : (1: Analog)
// (2: PWM )
// (3: UART )
// include
#include <htc.h>
#include "lcd.h"
#include "adc.h"
#include "system.h"
#include "uart.h"
// Configuration
___CONFIG(MCLRE_OFF & PWRTE_ON & WDTE_OFF & FOSC_INTRCIO);
// global variable
unsigned int To=0,T=0,TH=0;
unsigned char data[6] = {0};
// Interrrupt Subroutine
if (T0IF) // TMR0 is overflow
T0IF = 0; // clear flag bit
To +=0x100; // count number of TMR0 overflow ( make it to 16bit TMR)
if(RBIF) // there is change bit on RB4-RB7
RBIF = 0; // ____
if (PWM_IN) // PWM_IN(RB2) is 1 mean is rising form 0 __|
TMR0 = 0; // clear all counter involved, start new count for period of RB4 high
To = 0;
// ___
else TH = TMR0 + To; // PWM_IN(RB2) is 0 mean is falling form 1 |_____ // save TH, RB4 high period
// main function
void main(void)
unsigned char mode = 1;
PORTA = 0; // Clear Port
PORTB = 0;
PORTC = 0;
PORTD = 0;
TRISA = 0b11111111; // set PORTA as INPUT
TRISB = 0b00000111; // set PORTB<7:3> as OUTPUT , PORTB<2:0> as INPUT
TRISC = 0b10000000;
TRISD = 0b00000000; // set PORTD as output
ANSELH = 0; // SET PORTB as DIGITAL I/O for PIC16F887
WPUB = 1; // PORTB Weak Pull Up enable
// Interupt on change
IOCB0 = 0;
IOCB1 = 0;
IOCB2 = 1; // when PORTB.2 detect change will interrupt
IOCB3 = 0;
IOCB4 = 0;
IOCB5 = 0;
IOCB6 = 0;
IOCB7 = 0;
RBIE = 1; // PORTB Change Interrupt Enable bit
// TMR 0 configuation
T0CS = 0;
PSA = 0;
PS2 = 1; // prescale 1:256
PS1 = 1;
PS0 = 1;
T0IE = 1; // TMR0 Interrupt
TMR0 = 0;
GIE = 1; // Global Intterupt enable
PEIE = 1; // Peripheral Interrupt enable
lcd_initialize(); // Initialise LCD
adc_initialize(); // Initialise ADC
uart_initialize(); // Initialise UART
TX == 1; // ON Transmit pin (refer Maxbotix EZ1 Ultrasonic datasheet)
lcd_home();
lcd_putstr("Dist:");
lcd_goto(0x0B);
lcd_putstr("inch");
while (1)
switch(mode)
case 1: lcd_2ndline();
lcd_putstr("Analog");
while (SW1 == 1)
unsigned int adc_value = 0;
unsigned int range_an = 0;
unsigned char j;
adc_on();
for(j = 0 ; j < 10 ; j++) // take analog result for 20 times
adc_value = adc_value + ui_adc_read();
adc_value = adc_value/10; // adc_value devide by 10 to get average result
range_an = adc_value/2; // max vslue adc_value = 2.55/5 *1024 - 1 = 522
lcd_goto(0x05); // max is 254 inch... 522/254 = ~2
lcd_bcd(3,range_an); // (1 to 6 inch) is readed as 6 inch (refer to ultrasonic datasheet)
while (SW1 == 0);
break;
case 2: lcd_2ndline();
lcd_putstr("PWM ");
unsigned int range_pwm;
while(SW1 == 1)
range_pwm = TH; // read TH from interrupt subroutine
lcd_goto(0x05); // each value = 256*4/20mhz = 51.2us, 1 inch = 147us
range_pwm = (range_pwm*100)/288; // 147us/51.2us = 2.87
lcd_bcd(3,range_pwm);
while (SW1 == 0);
break;
case 3: lcd_2ndline();
lcd_putstr("UART ");
unsigned int value,k,l = 0;
while(SW1 == 1)
for (l=0 ; l<6 ; l++)
uc_uart_receive(); //take value from UART subroutine
if(RCREG == 'R') data[k=0] = RCREG; // check if start byte 'R' is met
if(data[0] == 'R') data[k++] = RCREG; // save the data in data array
if (k>4) k = 4; // if the data array reached max, set the index to 4
lcd_goto(0x05);
send_lcd_data(1,data[1]);
send_lcd_data(1,data[2]);
send_lcd_data(1,data[3]);
while (SW1 == 0);
if (++mode > 3) // if SW1 is press, increase the mode number until it is max and loop back
mode = 1;
But I got this error in the end
Clean: Deleted file "C:\Users\Yeo\Desktop\ETP\Project_6\adc.p1".
Clean Warning: File "C:\Users\Yeo\Desktop\ETP\Project_6\Project_6.p1" doesn't exist.
Clean: Deleted file "C:\Users\Yeo\Desktop\ETP\Project_6\lcd.p1".
Clean: Deleted file "C:\Users\Yeo\Desktop\ETP\Project_6\uart.p1".
Clean: Deleted file "C:\Users\Yeo\Desktop\ETP\Project_6\Project_6.mcs".
Clean: Done.
Build C:\Users\Yeo\Desktop\ETP\Project_6\Project_6 for device 16F887
Using driver C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Yeo\Desktop\ETP\Project_6\adc.c -q --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Yeo\Desktop\ETP\Project_6\Project_6.c -q --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [194] C:\Users\Yeo\Desktop\ETP\Project_6\Project_6.c; 20.11 ")" expected
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Yeo\Desktop\ETP\Project_6\lcd.c -q --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Yeo\Desktop\ETP\Project_6\uart.c -q --chip=16F887 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
********** Build failed! **********
Anyone can help me solve this problem??appricate!!
