Displaying Volume in ultrasonic range finder
Postby yeosteven » Sat Jul 14, 2012 11:01 pm
Guys....Anyone know how to change the program from inch to cm? Becuase I wan to program the software to let it calculate volume...where should I include the volume solution? THNKSS^^
//   Author            : CYTRON TECHNOLOGIES SDN BHD
//   Project            : SK40C sample code for PIC16F887
//   Project description   : Analog Sensor: Range using Ultrasonic Range Finder
//                    3 mode : (1: Analog)
//                           (2: PWM   )
//                           (3: UART  )
//   include
#include <htc.h>
#include "lcd.h"
#include "adc.h"
#include "system.h"
#include "uart.h"
//   Configuration
__CONFIG(HS &         // External Crystal at High Speed
       WDTDIS &      // Disable Watchdog Timer.
       PWRTEN &      // Enable Power Up Timer.
       BORDIS &      // Disable Brown Out Reset.
       MCLREN &      // MCLR function is enabled
       LVPDIS);      // Disable Low Voltage Programming.
//   global variable
unsigned int To=0,T=0,TH=0;
unsigned char data[6] = {0};
//  Interrrupt Subroutine
   if (T0IF)                        // TMR0 is overflow
      T0IF = 0;                      // clear flag bit
      To +=0x100;                     // count number of TMR0 overflow ( make it to 16bit TMR)
   if(RBIF)                        // there is change bit on RB4-RB7
      RBIF = 0;                     //                                           ____
      if (PWM_IN)                     // PWM_IN(RB2) is 1 mean is rising form 0  __|
         TMR0 = 0;                  // clear all counter involved, start new count for period of RB4 high
         To = 0;
                                 //                                 ___
      else TH = TMR0 + To;            // PWM_IN(RB2) is 0 mean is falling form 1       |_____  // save TH, RB4 high period
//   main function
void main(void)
unsigned char mode = 1;
   PORTA = 0;                     // Clear Port
   PORTB = 0;
   PORTC = 0;
   PORTD = 0;
   TRISA = 0b11111111;               // set PORTA as INPUT
   TRISB = 0b00000111;               // set PORTB<7:3> as OUTPUT , PORTB<2:0> as INPUT
   TRISC = 0b10000000;
   TRISD = 0b00000000;               // set PORTD as output
   ANSELH = 0;                   // SET PORTB as DIGITAL I/O for PIC16F887
   WPUB = 1;                     // PORTB Weak Pull Up enable
   // Interupt on change
   IOCB0 = 0;
   IOCB1 = 0;
   IOCB2 = 1;                     // when PORTB.2 detect change will interrupt
   IOCB3 = 0;
   IOCB4 = 0;
   IOCB5 = 0;
   IOCB6 = 0;
   IOCB7 = 0;
   RBIE = 1;                     // PORTB Change Interrupt Enable bit
   // TMR 0 configuation
   T0CS = 0;
   PSA = 0;
   PS2 = 1;                     // prescale 1:256
   PS1 = 1;
   PS0 = 1;
   T0IE = 1;                     // TMR0 Interrupt
   TMR0 = 0;
   GIE = 1;                     // Global Intterupt enable
   PEIE = 1;                     // Peripheral Interrupt enable
   lcd_initialize();               // Initialise LCD
   adc_initialize();               // Initialise ADC
   uart_initialize();               // Initialise UART
   TX == 1;                     // ON Transmit pin (refer Maxbotix EZ1 Ultrasonic datasheet)
   lcd_home();
   lcd_putstr("Dist:");
   lcd_goto(0x0B);
   lcd_putstr("inch");
while (1)
   switch(mode)
   case 1:         lcd_2ndline();
               lcd_putstr("Analog");
               while (SW1 == 1)
                  unsigned int adc_value = 0;
                  unsigned int range_an = 0;
                  unsigned char j;
                  adc_on();
                  for(j = 0 ; j < 10 ; j++)                  // take analog result for 20 times
                     adc_value = adc_value + ui_adc_read();
                  adc_value = adc_value/10;                  // adc_value devide by 10 to get average result
                  range_an = adc_value/2;                     // max vslue adc_value = 2.55/5 *1024 - 1 =  522
                  lcd_goto(0x05);                           // max is 254 inch... 522/254 = ~2
                   lcd_bcd(3,range_an);                     // (1 to 6 inch) is readed as 6 inch (refer to ultrasonic datasheet)
               while (SW1 == 0);
               break;
   case 2:         lcd_2ndline();
               lcd_putstr("PWM   ");
               unsigned int range_pwm;
               while(SW1 == 1)
                  range_pwm = TH;                           // read TH from interrupt subroutine
                  lcd_goto(0x05);                           // each value = 256*4/20mhz = 51.2us, 1 inch = 147us
                  range_pwm = (range_pwm*100)/288;            // 147us/51.2us = 2.87
                  lcd_bcd(3,range_pwm);
               while (SW1 == 0);
               break;
   case 3:          lcd_2ndline();
               lcd_putstr("UART   ");
               unsigned int value,k,l = 0;
               while(SW1 == 1)
                  for (l=0 ; l<6 ; l++)
                     uc_uart_receive();                     //take value from UART subroutine
                     if(RCREG == 'R') data[k=0] = RCREG;         // check if start byte 'R' is met
                     if(data[0] == 'R') data[k++] = RCREG;      // save the data in data array
                     if (k>4) k = 4;                        // if the data array reached max, set the index to 4
                     lcd_goto(0x05);
                     send_lcd_data(1,data[1]);
                     send_lcd_data(1,data[2]);
                     send_lcd_data(1,data[3]);
      while (SW1 == 0);
      if (++mode > 3)             // if SW1 is press, increase the mode number until it is max and loop back
         mode = 1;
yeosteven
Re: Displaying Volume in ultrasonic range finder
Postby yonghui » Mon Jul 16, 2012 12:54 pm
the ultrasound sense the distance only unless u have the other 2 dimension fix and u need only one dimension to get the volume.
1inch =2.54cm, so in the software just multiply the inch result with 2.54 to get the cm distance.
