UIC00A
UIC00A
Postby rexwong0211 » Sat Dec 29, 2012 2:18 am
Help !! I was using UIC00A and im try do work on debugger mode. I mistakenly supply external and internal supply to my board, but after that i made adjustment it work smoothly. But, on the next day suddenly UIC00A cant be detected !! Did i burn it ? (the green light is still on)
rexwong0211
Re: UIC00A
Postby zhenning » Sat Dec 29, 2012 2:22 am
Check the device manager? Or try to reinstall the driver? It may help.
zhenning
Re: UIC00A
Postby rexwong0211 » Sat Dec 29, 2012 2:38 am
thz for reply !! i dont thk device manager have it, bcoz it dont even have the pop up USb thing.
how to reinstall the driver, bcoz i didnt install it at the 1st place ?
rexwong0211
Re: UIC00A
Postby zhenning » Sat Dec 29, 2012 2:53 am
Look inside the device manager. It should show all connected devices. It there is no driver, then you will see a yellow question mark. If the driver is installed, uninstall it :)
zhenning
Re: UIC00A
Postby rexwong0211 » Sat Dec 29, 2012 2:14 pm
i tried plug and unplug the programmer while looking at the device manager, nothing pop up. But when i replace UIC00A with UIC00B, it work fine. So, i need to know how to make sure that UIC00A burned ? with the green light still on.
Or did i accidently erase smthg in it ?
rexwong0211
Re: UIC00A
Postby zhenning » Sat Dec 29, 2012 2:25 pm
The green led is just the power indicator to indicate the 5V. Is there any other activity on the other leds?
rexwong0211 WROTE: I mistakenly supply external and internal supply to my board
How many volts? If its more than 5V, then, most likely its gone.
zhenning
Re: UIC00A
Postby rexwong0211 » Thu Feb 14, 2013 4:56 pm
it is very possible it is gone bcauze i try the same thg with other device n they work all juz fine. thz for the hlp
rexwong0211
