UIC00B stepping non stop and finally MPLAB IDE hang
Postby khmok » Fri Mar 29, 2013 3:22 pm
When I step through my code, I noticed that when come to bit shifting (data >> = 1), the UIC00B will step non-stop and finally hang.
Refer my code below.
Do you encounter the same thing? Please give some advice how to solve this.
void OWWriteByte(int data)
   int i = 0;
   // Loop to write each bit in the byte, LS-bit first
   for (i= 0; i < 8; i++)
      OWWriteBit(data & 0x01);
      // shift the data byte for the next bit
      data >> = 1;
khmok
Re: UIC00B stepping non stop and finally MPLAB IDE hang
Postby robosang » Tue Apr 02, 2013 10:43 pm
what does "data >> = 1" means?
Postby Brian Griffin » Wed Apr 03, 2013 12:08 am
data >>= 1 is also:
data = data >> 1
