Interfacing IFC-BH02 with Planetary DC Gear Motor
Postby pradeep20 » Wed Apr 10, 2013 7:18 am
Hey Guys,
wish to ask, how am I supposed to interface the Planetary motor with the IFC
dual brush card and still maintain the bidirectional characteristic of the planetary motor encoder?
When i check the dual brush card, there is only 3 pins for encoders( for each port), that is 2 for Vcc and
Ground and the other for Signal, whereas the planetary motor has two signal wires
( channel A and Channel B). The data sheet says that if Ch A lead Ch B, its increasing and
likewise. Hope someone can be kind enough to shed some light onto this topic for me.
Thank You :)
pradeep20
Re: Interfacing IFC-BH02 with Planetary DC Gear Motor
Postby robosang » Wed Apr 10, 2013 10:16 pm
I never use IFC, I know is from Cytron, but I do not need it :twisted:
Anyway, can you show the link of the product so other can get it easily?
Postby pradeep20 » Thu Apr 11, 2013 3:43 am
Thank you for your reply :)
here is the link of the IFC Dual Brush Card.
http://www.cytron.com.my/viewProduct.ph ... tor%20Card
and this is the link to the planetary motor
http://www.cytron.com.my/viewProduct.ph ... or%20(42mm)
pradeep20
Postby robosang » Thu Apr 11, 2013 10:28 am
Looking at the layout and schematic of BH02, it only take 1 input for encoder, I don think it can support 2 channels encoder which is needed for you to know direction.
But you control the motor, so you should know the direction, the encoder can provide rotation.
