SK40C Work, But LCD FAILED
Postby pikachuX » Wed Jun 18, 2014 1:15 am
Hi guys,
I had burn the coding into the pic that provided from cytron sk40c page. But there is nothing happen after i burn in the program to pic. Is there any place i need to solder it ?
Is there necessary to buy the LCD from cytron ? because i buy the LCD from electronics shop.
Should be no problem right since the model also is 16x2 ?
I had solder all the pin like this.
Coding:
//   Author               : CYTRON
//   Project               : SK40C Led Blinking
//   Project description      : Blink RB6 and RB7 LED
//                       This sample source code is valid for 20MHz crystal.
//   include
#include <pic.h>
//configuration
__CONFIG ( 0x3F32 );      //configuration for the  microcontroller
//   define
#define   rs         RB4         //RS pin of the LCD display
#define   e         RB5         //E pin of the LCD display
#define   lcd_data   PORTD      //LCD 8-bit data PORT
#define   SW1         RB0
#define   SW2         RB1
#define   LED1      RB6
#define   LED2      RB7
//   function prototype      (every function must have a function prototype)
void lcd_clr(void);
//   global variable
//   main function               (main fucntion of the program)
void main()
   unsigned long delay_time=5000;
   //set I/O input output
   TRISB = 0b00000011;            //configure PORTB I/O direction
   TRISD = 0b00000000;            //configure PORTD I/O direction
   TRISA = 0b00000111;            //configure PORTA I/O direction
   //setup ADC
   ADCON1 = 0b00000110;            //set ADx pin digital I/O
   //configure lcd
   send_config(0b00000001);         //clear display at lcd
   send_config(0b00000010);         //lcd return to home
   send_config(0b00000110);         //entry mode-cursor increase 1
   send_config(0b00001100);         //display on, cursor off and cursor blink off
   send_config(0b00111000);         //function set
   //display startup message
   lcd_clr();                     //clear lcd
   lcd_goto(2);                  //set the lcd cursor to location 0
   send_string("Cytron Tech.");      //display "Cytron Tech."
   lcd_goto(26);                  //set the lcd cursor to location 20
   send_string("SK40C");            //display "SK40C"
   LED1=0;                        //OFF LED1
   LED2=0;                        //OFF LED2
   while(1)                     //Infinite loop
      if(!SW1)                  //check if SW1 is pressed
         while (!SW1);            //wait SW1 pressed
            delay_time+=1000;      //delay
      else if(!SW2)               //check if SW2 is pressed
         while (!SW2);            //wait SW2 pressed
            delay_time-=1000;      //delay
      LED1^ = 1;               //toggle LED1
      delay(delay_time);
      LED2^ = 1;               //toggle LED2
      delay(delay_time);
//   functions
void delay(unsigned long data)         //delay function, the delay time
{                              //depend on the given value
   for( ;data>0;data--);
void send_config(unsigned char data)   //send lcd configuration
   rs=0;                        //set lcd to configuration mode
   lcd_data=data;                  //lcd data port = data
   e=1;                        //pulse e to confirm the data
   delay(50);
   e=0;
   delay(50);
void send_char(unsigned char data)      //send lcd character
    rs=1;                        //set lcd to display mode
   delay(10);
   e=0;
   delay(10);
void lcd_goto(unsigned char data)      //set the location of the lcd cursor
{                              //if the given value is (0-15) the
    if(data<16)                     //cursor will be at the upper line
   {                           //if the given value is (20-35) the
       send_config(0x80+data);         //cursor will be at the lower line
   }                           //location of the lcd cursor(2X16):
   else                        // -----------------------------------------------------
   {                           // | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
       data=data-20;               // | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
      send_config(0xc0+data);         // -----------------------------------------------------
void lcd_clr(void)                  //clear the lcd
    send_config(0x01);
   delay(600);
void send_string(const char *s)         //send a string to display in the lcd
   while(TXIF==0);                  //only send the new data after
   TXREG=data;                     //the previous data finish sent
Regards,
YY
pikachuX
Re: SK40C Work, But LCD FAILED
Postby ober » Wed Jun 18, 2014 8:49 am
Can you show the picture when the power is activated?
Postby pikachuX » Thu Jun 19, 2014 7:43 am
pikachuX
Postby ober » Thu Jun 19, 2014 8:07 am
OK, the power is working, LCD showing symptom that it is not initialize yet. How about LEDs? According to the sample code, both LEDs should blinking alternately.
As far as I use LCD, if the pins are compatible, the protocol should be compatible, task the sample code should work. If SK40C works but LCD is not working, do check the soldering of the LCD with SK40C.
Postby Brian Griffin » Thu Jun 19, 2014 8:38 am
Resit the 20MHz crystal. Push it down and shake it a bit. It seems that the crystal is a bit loose on the SK40C boards.
Postby pikachuX » Fri Jun 20, 2014 1:35 pm
i think the soldering should be no problem, because it not touching each others.
pikachuX
Postby ober » Fri Jun 20, 2014 5:37 pm
Yes, it is not short between pins, but some of the pins seem to be not connected to SK40C, from the back, you need to verify that too.
