source code for remote mobile robot
Postby fana » Thu Jan 22, 2015 12:27 am
how to get source code for UIC00B and PIC 16F887? Please help me :cry: . tq
fana
Re: source code for remote mobile robot
Postby yonghui » Thu Jan 22, 2015 9:57 pm
Just search for sample projects that are using that particular PIC.
Postby ober » Fri Jan 23, 2015 11:42 am
You can try MC40A sample code, it is using PIC16F887. Do check out the User's manual.
Postby fana » Mon Feb 02, 2015 11:21 pm
how to fixed this ?? :roll: :roll: :?: :cry: :cry: :cry:
fana
Postby Idris » Tue Feb 03, 2015 9:10 am
Hi fana,
Based on the picture you share, it seems like you are using PIC16F887 and MPLAB X to compile source code. So why don't you directly upload the code to PIC using MPLAB X too?
Normally we don't set the configuration bit on PICkit 2 software, because it is already set in the hex file.
Postby fana » Wed Feb 04, 2015 4:36 pm
why its running target take long time and not ending? :roll: :roll:
i want to ask, did we need to converting an MPLAB v8 project to MPLAB X?
i use MPLAB X IDE v2.30.. i follow the step based on this link http://tutorial.cytron.com.my/2012/07/0 ... mplab-xc8/
fana
Postby ober » Wed Feb 04, 2015 9:10 pm
Running target means.... the code is being loading into target board, in this case the MC40A and the program is already running.
Postby fana » Thu Feb 05, 2015 11:19 pm
fana
Postby Idris » Fri Feb 06, 2015 8:52 am
If the project file is in MPLAB v8 format and you want to open it with MPLAB X, yes you need to convert.
But, if the project file already in MPLAB X format, then you don't need to convert, you can directly open it on MPLAB X.
Postby anhtran19932111 » Mon Mar 06, 2017 10:56 am
anhtran19932111
