The PWM Troubles about PIC18F46K22
Postby formafrost » Wed Jun 07, 2017 4:36 pm
Hello,
The following program is written by myself, but it have never simulated successfully. Can anyone here give me some advice? Thank you at advance.
#include <xc.h>
#include"config.h"
#define _XTAL_FREQ 4000000
#define INT8U unsigned char
#define INT16U unsigned int
void Init_PWM();
void PWM_OUT(INT16U PwmOut);
//__delay_ms();
//__delay_us();
//*******main program***********
void main()
    INT16U x0 = 512;
    Init_PWM();
        PWM_OUT(x0);
void Init_PWM()
    TRISCbits.RC2 = 1; //RC2/CCP1 set as output banning
    ANSELCbits.ANSC2 = 0;  //enable digital output function
//    CCPTMRS0bits.C1TSEL1 = 0;
//    CCPTMRS0bits.C1TSEL0 = 0;
    CCPTMRS0bits.C1TSEL = 0x0;   //0000 0000 CPP1 PWM use TMR2
    PR2 = 124;  //The timer in the preliminary:PR2=[500/(4*0.25*4)]-1=124=0x7C
//    CCP1CONbits.CCP1M3 = 1;
//    CCP1CONbits.CCP1M2 = 1;
//    CCP1CONbits.CCP1M1 = 0;
//    CCP1CONbits.CCP1M0 = 0;
    CCP1CONbits.CCP1M = 0xC; //0000 1100 set as PWM module
    CCP1CONbits.DC1B1 = 0;
    CCP1CONbits.DC1B0 = 0;
    CCPR1L = 0x80;           //0000 00[10 0000 00]00 The initial duty ratio is 50%
    PIR1bits.TMR2IF = 0;  //Reset the interrupt flag bit
//    T2CONbits.T2CKPS1 = 0;
//    T2CONbits.T2CKPS0 = 1;
    T2CONbits.T2CKPS = 0x1; //TMR2 Choose four frequency division
    T2CONbits.TMR2ON = 1; //Open the timer
    TRISCbits.RC2 = 0; //RC2/CCP1 Set to the output
//    PIE1bits.TMR2IE = 1;
//    INTCONbits.GIE = 1;
    CCP1CONbits.DC1B1 = (bit)(PwmOut >> 1);
    CCP1CONbits.DC1B0 = (bit)PwmOut;
    CCPR1L = (INT8U)(PwmOut >> 2);
//===================================Configure bit setting=========================================================
// CONFIG1H
#pragma config FOSC = XT        // Oscillator Selection bits (XT oscillator)
#pragma config PLLCFG = OFF     // 4X PLL Enable (Oscillator used directly)
#pragma config PRICLKEN = ON    // Primary clock enable bit (Primary clock is always enabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRTEN = ON      // Power-up Timer Enable bit (Power up timer enabled)
#pragma config BOREN = NOSLP    // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled))
#pragma config BORV = 285       // Brown Out Reset Voltage bits (VBOR set to 2.85 V nominal)
// CONFIG2H
#pragma config WDTEN = SWON     // Watchdog Timer Enable bits (WDT is controlled by SWDTEN bit of the WDTCON register)
#pragma config WDTPS = 1        // Watchdog Timer Postscale Select bits (1:1)
// CONFIG3H
#pragma config CCP2MX = PORTB3  // CCP2 MUX bit (CCP2 input/output is multiplexed with RB3)
#pragma config PBADEN = ON      // PORTB A/D Enable bit (PORTB<5:0> pins are configured as analog input channels on Reset)
#pragma config CCP3MX = PORTB5  // P3A/CCP3 Mux bit (P3A/CCP3 input/output is multiplexed with RB5)
#pragma config HFOFST = OFF     // HFINTOSC Fast Start-up (HFINTOSC output and ready status are delayed by the oscillator stable status)
#pragma config T3CMX = PORTC0   // Timer3 Clock input mux bit (T3CKI is on RC0)
#pragma config P2BMX = PORTD2   // ECCP2 B output mux bit (P2B is on RD2)
#pragma config MCLRE = EXTMCLR  // MCLR Pin Enable bit (MCLR pin enabled, RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON         // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled if MCLRE is also 1)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection Block 0 (Block 0 (000800-003FFFh) not code-protected)
#pragma config CP1 = OFF        // Code Protection Block 1 (Block 1 (004000-007FFFh) not code-protected)
#pragma config CP2 = OFF        // Code Protection Block 2 (Block 2 (008000-00BFFFh) not code-protected)
#pragma config CP3 = OFF        // Code Protection Block 3 (Block 3 (00C000-00FFFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection Block 0 (Block 0 (000800-003FFFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection Block 1 (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF       // Write Protection Block 2 (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF       // Write Protection Block 3 (Block 3 (00C000-00FFFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection Block 0 (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection Block 1 (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection Block 2 (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection Block 3 (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
This is the datasheet of PIC18F46K22: http://www.kynix.com/uploadfiles/pdf65976/PIC18F46K22-E2fPT_750483.pdf and the schamatic diagram is given below.
Best regards~
formafrost
