Posted by Nazri:
"I have your old UP00A PIC USB Programmer and try to figure-out how to use its ICSP function. I've wired up my circuit using PIC16F877A and download into it few programs using the normal 40-pin socket by plug-in and plug-out the IC. It works perfectly.
The problem is, I want to use the ICSP function and wired up my circuit as required from your user's manual. I've connected my circuit and the ICSP terminal on the UP00A with 5-wired ribbon cable and connector. I couldn't get any response of downloading software into the PIC IC. I opened up your WinPic800 -> Settings -> Hardware to change the Blockade Configuration, but it does not want to be saved, as I thought I need to try changing some options there in order to make it works.
Please help me on how to start using the ICSP function from the programmer. I'm stuck now."
