Can not run the test program of Pioneer600 HAT
PostPosted: Thu Mar 21, 2019 4:59 pm
by clarenceooi
Hi, I follow the manual and try to test the LED,BMP, DS3231 clock, and PCF8574 in Python folder.
For LED test, I can run the python and see the expected result.
For BMP280,sudo an error message occurred: Read BMP280 id error!
For DS3231, the command return time and date but it is at 200/00/00 00:00:00 Sat, and no change in second although the line
keep running.
For PCF8574, the command line return "left", but nothing happen when I push the joystick left, or any other directions.
Looks like only LED is working, please advise. Thanks.
Re: Can not run the test program of Pioneer600 HAT
PostPosted: Thu Mar 21, 2019 5:30 pm
by ZaM
Sorry about that, we will verify with manufacturer first (Waveshare).
Because all library is seen created at 2015.
Verification will take time.
PostPosted: Thu Mar 21, 2019 6:09 pm
by clarenceooi
Please get them to confirm also whether the BMP onboard the Pioneer600 is BMP180 or BMP280. Both of them are included in the folder but I believe the hardware should be only one. I tried to use magnifying glass to see the chip but there is no indication of model. I can only see a label "OTQ KW".
Thank you.
ZaM WROTE:Hi,
PostPosted: Fri Mar 22, 2019 10:02 am
by ober
From the diagram and schematic, it is BMP280. But we will verify that on the actual hardware.
PostPosted: Fri Mar 22, 2019 12:42 pm
by clarenceooi
Hi, I tried to run the BMP280.py and it is running, so should be BMP280. However the reading is totally out, temperature is 31 degree Celsius and Pressure is 100.5kpa. But I am in a aircon room of about 21 degree Celsius.
Please advise, thanks.
ober WROTE:From the diagram and schematic, it is BMP280. But we will verify that on the actual hardware.
PostPosted: Wed Mar 27, 2019 6:09 am
by ober
Can you try to heat up the BMP280 maybe by blowing your breath to it? The pressure reading is kind of close to standard atmospheric pressure, which is 101.325kpa (according to Wiki:https://en.wikipedia.org/wiki/Atmospheric_pressure).
As for the higher temperature reading, according to supplier, it is due to the heat generated by raspberry pi itself when it is in operation.
If the reading changes to higher as you blow hot air to it, it should be working.
