SPG 30-30K (HOW TO READ THE ENCODER OF THIS GEARED DC MOTOR
Re: SPG 30-30K (HOW TO READ THE ENCODER OF THIS GEARED DC MO
Postby fendy90 » Tue Nov 20, 2012 8:18 pm
hey there, im using arduino in coding the (Rotary Encoder B-106-23983,
1.is there any coding for arduino to determine or serialprint out the RPM of the encoder?
2.what is the value coming out from the yellow wire as shown in data sheet?? is it value of pulse frequency?
im currently using this code
int ledPin = 13;                // IR LED connected to digital pin 13
volatile byte rpmcount;
unsigned int rpm;
unsigned long timeold;
int val1 = 2;
// include the library code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
void rpm_fun()
   //Each rotation, this interrupt function is run twice, so take that into consideration for
   //calculating RPM
   //Update count
      rpmcount++;
   lcd.begin(16, 2);  // intialise the LCD
   //Interrupt 0 is digital pin 2, so that is where the IR detector is connected
   //Triggers on FALLING (change from HIGH to LOW)
   attachInterrupt(0, rpm_fun, FALLING);
   //Turn on IR LED
   pinMode(ledPin, OUTPUT);
   pinMode(val1,INPUT);
   digitalWrite(ledPin, HIGH);
   rpmcount = 0;
   rpm = 0;
   timeold = 0;
   //Update RPM every second
   delay(1000);
   //Don't process interrupts during calculations
   detachInterrupt(0);
   //Note that this would be 60*1000/(millis() - timeold)*rpmcount if the interrupt
   //happened once per revolution instead of twice. Other multiples could be used
   //for multi-bladed propellers or fans
   rpm = 30*1000/(millis() - timeold)*rpmcount;
   timeold = millis();
   rpmcount = 0;
   //Print out result to lcd
   lcd.clear();
   lcd.print("RPM=");
   lcd.print(rpm);
   Serial.println(rpm);
   //Restart the interrupt processing
fendy90
Postby robosang » Tue Nov 20, 2012 11:36 pm
Have you visit the tutorial by Cytron?
Previous
Return to DC Motor
