Coupling and bracket for DC motor
Postby homeboy » Tue Dec 29, 2009 3:50 pm
hi, is the coupling and bracket at will fit with my DC motor? my Dc motor model is SPG30-30K
i will purchase if it can fit with my DC motor..
thanks
1) http://www.cytron.com.my/listProductGro ... JpqNd2y2I=
2) http://www.cytron.com.my/listProductGro ... tp7v6Nz9s=
homeboy
Re: Coupling and bracket for DC motor
Postby robosang » Tue Dec 29, 2009 4:10 pm
I think the website should mention what motor is suitable for it right? Did you check the page?
Postby ober » Wed Dec 30, 2009 10:33 am
Yup, the description is stated under the product page.
Postby homeboy » Thu Jan 07, 2010 1:25 pm
any idea to combined with the DC motor, while how to find the suitable nut for this bracket. thanks
homeboy
Postby robosang » Thu Jan 07, 2010 5:16 pm
I think is M3 bolt because I have been using the SPG30 motor from Cytron. Remember, don buy a too long bolt, you might damage the internal gearing when you screw it in. That was what I did once :|
Postby sich » Tue Jan 12, 2010 4:04 pm
The specification document given mentioned the max depth of 3.5mm for the four mounting holes at the SPG30-30K gearhead. So it means the part of the screws that you tighten into the holes shouldn't be longer than 3.5mm.
