Dc Motor must be supply with rated voltage?
Posted: Fri Jan 08, 2010 8:44 pm
Hi, i bought one of the dc motor from cytron.
The rated voltage for the dc motor is 12v.
I did the experiment, as long as i supply enough current to the motor, the motor run although the supply voltage is below 12v. why ?
So, can i just use the 9V battery supply to operate it for long hours?
My friend suggest me to supply the rated voltage anyway since it is rated.
So can i have you guy suggestion and the reason ?
Thank a lot.
Thank a lot.
