servo motor c40s
servo motor c40s
Postby mooookoooo » Wed Mar 10, 2010 1:15 am
hi, I am now learning on how to control the servo using pwm. just want to know that the total time of pwm(20ms according to cytron program) can be used at any value of crystal? currently using pic16f84a with 4mhz crystal.
mooookoooo
Re: servo motor c40s
Postby A380 » Wed Mar 10, 2010 8:04 pm
No PWM module is available for PIC16F84A. I think you should use Timer 0 interrupt to control your servo motor. Set prescaler to 1:128 if you are using 4MHz oscillator.
A380
Postby Benjamin » Fri Sep 24, 2010 4:25 pm
If i using 20MHz oscillator?and can i use pic16f876?
Benjamin
Postby redips_id » Fri Sep 24, 2010 6:33 pm
Benjamin WROTE:If i using 20MHz oscillator?and can i use pic16f876?
Of course you can, by using timer interrupt you can produce 50Hz and control servo position.
redips_id
Postby Benjamin » Fri Sep 24, 2010 7:48 pm
Did there any e-book for references in programming c language in pic16f876?
Benjamin
Postby shahrul » Mon Sep 27, 2010 2:41 am
Benjamin WROTE:Did there any e-book for references in programming c language in pic16f876?
You can view many example source code here.
Postby SnowLeopard » Mon Oct 04, 2010 1:51 pm
Hi mr Shahrul. Good job on your technology and engineering blog. =)
SnowLeopard
