Servo Motor C36R
Servo Motor C36R
Postby ken_alone » Thu Mar 11, 2010 11:17 am
Hi there... I would like to ask whether the C36R motor can be programmed to be rotate continuosly?I mean when i push assigned button and it rotates continously untill i let off the button... And how was the program looks like coz i could find it.... :(
ken_alone
Re: Servo Motor C36R
Postby ober » Thu Mar 11, 2010 12:42 pm
Hi, standard RC servo cannot rotate 360 degree or continuous, limited hardwarely. Anyhow, Cytron do provide modified servo where it become normal DC brush motor with geared. Those motors will rotate continuously when power is apply. Thus, your requirement cannot be done with standard RC servo. If you use modified servo, it become normal DC motor.
Postby ken_alone » Thu Mar 11, 2010 10:12 pm
If i change it to C36S, would it be possible to function with IFC servo card? coz i connected once but it juz rotate without being controlled once i on the supply...
ken_alone
Postby sich » Fri Mar 12, 2010 7:45 pm
ken_alone WROTE:If i change it to C36S, would it be possible to function with IFC servo card? coz i connected once but it juz rotate without being controlled once i on the supply...
C36S (360 DEGREE) is normal brushed motor in servo casing. U'll need IFC-BH02 to drive it.
Postby maxx » Sun Jul 17, 2011 7:38 am
operate voltage for C36S is max 7v. if i'm right IFC-BH02 is operate on 12v. that is ok if i connect IFC-BH02 to C36S directly? or connector "H" on IFC, i connect another power supply for C36S?
maxx
