DC motor driver
DC motor driver
Postby tschua » Fri May 21, 2010 6:07 pm
Hey, i am currently constructing a brush motor driver using 2 relay and 1 MOSFET. My problems is the MOSFET is getting HOT very fast and always burn. Is there any solution? I am using IRFZ44N. I saw cytron's product MD10B (Enhanced 10 Amp DC Motor Driver), the MOSFET doesn't attach heat sink. I wonder would it get HOT? Further more, the 4 diodes (1N4007)for EMF would effect the MOSFET? Image
tschua
Re: DC motor driver
Postby A380 » Fri May 21, 2010 11:03 pm
Schottky diode should be used in this case. How much current for your motor? If less than 1A, 1N5818 or 1N5819 is recommended. If less than 3A, IN5822 should be used. Mosfet should be fully ON (Vgs > 8V but max Vgs is 20V for IRFZ44N) to reduce the heat. Schematic which shown below is recommended.
A380
Re: DC motor driver
Postby tschua » Sat May 22, 2010 8:32 pm
Thanks for replying. I will try your suggestion and let you know the result asap.
tschua
PWM inverse proportional to speed
Postby tschua » Sat May 29, 2010 5:59 pm
I had tried the connection. The speed of motor become inverse proportional to the PWM.
PWM 100%, motor stop; PWM 0%, motor full speed.
Then I tried this connection, but the Gate signal is not very good.
In case I don't want to change my programming, is there any other methods to drive MOSFET?
tschua
Re: DC motor driver
Postby ober » Tue Jun 01, 2010 3:36 pm
I don think that is correct way to drive a NPN BJT transistor......
Re: DC motor driver
Postby royalstorm7 » Tue Sep 07, 2010 3:32 pm
sure....the motor was overloaded...or....undersized mosfet.....i slighly dont agree with the a380 circuit...
royalstorm7@yahoo.com
royalstorm7
