RC Micro Servo Motor C17S
Postby sure05resh » Thu Nov 18, 2010 9:03 am
hi there..
may i de the specs of the motor
in terms of angles,power, how to setup and etc..
tq.
sure05resh
Re: RC Micro Servo Motor C17S
Postby hyng » Thu Nov 18, 2010 9:49 am
Normally there is no datasheet given for the servo motor.
Therefore, you need to test an error to figure out the angle. Anyway, the pulse width range is estimated between 0.5ms until 2.5ms. The power for servo motor is between 5-6V. Please note that you should not supply more than 6V to the servo motor. Other wise the motor may damage.
Normally a standard servo motor has 3 wires, Chocolate/black, red and orange/white. Red is positive, chocolate/black is negative and orange/white is signal. You may connect directly the signal to the output of your microcontroller. The sample source code is given in the product page. You can refer to it.
Postby sure05resh » Thu Nov 18, 2010 1:26 pm
tq for ur reply..
wat is the estimate weight of object that can mount on Micro Servo Motor C17S?
my object is less than 100grams.. izzit possible to rotate?
sure05resh
Postby kl84 » Fri Nov 19, 2010 1:21 am
The torque needed to rotate your object also depends on the distance of the object to the motor shaft. If the distance is longer, the moment of force is higher and the torque needed will be higher too.
So there's no absolute answer for your question with the info you gave.
kl84
