SPG30-30K
SPG30-30K
Postby bubbletea7 » Sun Mar 06, 2011 2:05 am
HELLO,
I AM USING THIS DC GEARED MOTOR,
CAN THIS MOTOR CALLED AS A SERVO MOTOR?
IF YES, HOW DOES THIS MOTOR WORK?
TQ FOR REPLYING..
bubbletea7
Re: SPG30-30K
Postby yonghui » Sun Mar 06, 2011 8:52 am
normal DC gear motor is different from servo.
servo can be used in positioning, but DC gear motor, we hardly knows the position.
Re: SPG30-30K
Postby sich » Tue Mar 08, 2011 1:31 am
Servo is actually referring to a system with feedback or error-correction signals to help achieve the desired output, such as position, speed, temperature and water level. Without servo, a system is open-loop.
So a servo motor is a motor with feedback signal to control the position of the shaft or speed of rotation. I think you're asking about the rc servo motor. This site gives you the comparison:
http://handyboard.com/hb/faq/hardware-faqs/dc-vs-servo/
