DC motor
Re: DC motor
Postby picpicpikapika » Mon Mar 28, 2011 9:22 am
I think I am going to use a pair of 9V battery to drive my car...actually I need it to sustain around five minutes...I think a pair of nine volt battery should be able to do that...for the connection, can I straight away parallel it, or I need to add any circuit components for safety precaution?
Thanks a lot...
picpicpikapika
Re: DC motor
Postby kl84 » Mon Mar 28, 2011 3:43 pm
Yes, you can parallel them. Usually it's okay to do so for the same type of battery, eg: NOT putting AA & 9V in parallel.
However, like shiyan mentioned, 9V battery is not suitable for this kind of application. I personally will use rechargeable AA batteries if LiPo is not available.
kl84
Re: DC motor
Postby picpicpikapika » Wed Mar 30, 2011 5:29 am
Can I still use the voltage regulator 7805 to regulate lipo battery???...Is this battery too heavy for the mcu??
picpicpikapika
Re: DC motor
Postby sich » Wed Mar 30, 2011 1:53 pm
picpicpikapika WROTE:Can I still use the voltage regulator 7805 to regulate lipo battery???
Of course. As long as the voltage doesn't exceed 7805's max Vin.
picpicpikapika WROTE:Is this battery too heavy for the mcu??
Heavy in term of weight? Depends on the size. There's smaller LiPo batt at 1100mAH, 7.4V, ~100g, 70mm x 33mm x 15mm.
Heavy in term of power? Not a valid statement in this case. Your mcu only takes as much current as it needs, no matter how much more the power source (eg: battery) can supply.
Re: DC motor
Postby picpicpikapika » Fri Apr 01, 2011 9:29 am
I am thinking of using two power supplies, one will be a nine volts battery, i am using it to power up mcu, ir sensor and motor driver( I am using L293D motor driver to drive the motors), another one is four AA 1.5V batteries, I am using it to supply power to pin 8 of the motor driver(this pin is for the motor power)...
Is this ok??
Besides, I have tried to run my racing car...it is working but it can't go straight although the motor driver has supplied two same magnitude voltage to the motors...please give me some suggestion thanks a lot
picpicpikapika
Re: DC motor
Postby sich » Fri Apr 01, 2011 10:01 am
picpicpikapika WROTE:it is working but it can't go straight although the motor driver has supplied two same magnitude voltage to the motors...
This is quite common especially for Tamiya motors. Many factors contribute to it, eg: different motor's performance, gear friction, wheels...
Usually if we're using microcontroller in the system, we'll tune the PWM given by microcontroller to L293D motor driver. It means each motor will get different PWM value so that as a result, both can rotate at almost same speed. Then the RC car can go straight.
Re: DC motor
Postby picpicpikapika » Sat Apr 02, 2011 7:24 am
Thanks a lot...
Can I connect a capacitor across my dc motor??? Why type of capacitor can I use??
picpicpikapika
Re: DC motor
Postby A380 » Mon Apr 04, 2011 5:35 pm
Normally we place a ceramic capacitor 0.1uF (104) parallel to motor terminals.
A380
Re: DC motor
Postby picpicpikapika » Mon Apr 11, 2011 8:27 am
Hi all the experts here,
I have finished my project and the project presentation was quite successful...
Thank you very much for all the assistance and suggestions...
Thanks a lot. :D
picpicpikapika
Re: DC motor
Postby sich » Mon Apr 11, 2011 10:20 am
Well done! We're glad that you find this forum helpful! ;)
Previous
Return to DC Motor
