C40R & ARDUINO Problem
Postby qut11 » Thu Jan 26, 2012 11:29 am
Hi guys, i recently purchased a c40r servo motor and an arduino uno... I'm pretty new to all of this, so i was attempting to try n control my servo motor using the arduino... i used the servo example given on the arduino IDE, but it only resulted in my servo moving in random motion... so i figured it could be a problem with the clock maybe? does the servo require a 20MHZ clock, or is the 16MHZ clock on the arduino sufficient? can you all please help me, i really need this urgently =(
qut11
Re: C40R & ARDUINO Problem
Postby shahrul » Thu Jan 26, 2012 3:34 pm
Where you connect servo power? Servo supply need higher current, can't feed from arduino, USB or low energy battery.
Postby robosang » Thu Jan 26, 2012 11:47 pm
Agreed with shahrul, high chance is due to insufficient current. USB is out of question :) You try 2A adapter/battery.
Postby qut11 » Fri Jan 27, 2012 10:56 am
i dont understand how this works, either there is a problem with the servo, or i am doing it wrong... is the servo dependent on the voltage or the current?? when i attach an external 5-6 Volt voltage, it barely moves... when i attach the servo on the arduino 5v pin, it moves inconsistently and randomly.. the only thing that seemed to make it work is when i attached it to the arduino 3.3v pin- altho it was rotating accordingly, the rotations were not smooth at all... any help would be much appreciated :(
qut11
Postby hyng » Wed Feb 01, 2012 10:35 am
Do not supply the servo's power from Arduino Board if the Arduino is power from USB. You can try to power up the Arduino by using Adapter 2A.
