Control C36R servo using PIC16F88
Postby yeekang92 » Thu Oct 18, 2012 8:15 pm
Hey guys,
I'm new here and I need your help. I'm doing a project which requires to obtain an input in circular motion and I've decided using potentiometer as the input. With PIC16F88 as the micro controller how should I program it to read the input from the potentiometer and then generate an output to the servo motor? Do I have to buy a servo controller similar to the video below? Thanks in advance :)
yeekang92
Re: Control C36R servo using PIC16F88
Postby yonghui » Thu Oct 18, 2012 11:03 pm
how many pcs of sevo u are goin to control. the rc servo is controlled by pulse width, so if are controlling alot servo then probably u will need the servo controller.
Postby yeekang92 » Thu Oct 18, 2012 11:10 pm
yonghui WROTE:how many pcs of sevo u are goin to control. the rc servo is controlled by pulse width, so if are controlling alot servo then probably u will need the servo controller.
I only got 1 servo to control. so it means that I dont need to get that servo controller? and can you teach me of how to do the programming similar to what he is doing in the video? Thanks alot :)
yeekang92
Postby gadgetng » Fri Oct 19, 2012 12:07 pm
Do some study on:
1. How to read the analog value from the potentiometer.
Example:
http://tutorial.cytron.com.my/2011/08/09/project-4-%E2%80%93-analog-sensor-potentiometer-bb-psj/
2. How to control the servo motor.
Example from sample source code:
http://www.cytron.com.my/viewProduct.php?pcode=C40R&name=RC%20Servo%20Motor
Only then you try combine both in one code to get what you want. I also found out that the DIY project http://www.cytron.com.my/viewProduct.php?pid=HSwOBiUpOBAaOR0OAjEDJfMqSBbl1cpR/xbsOOT6uNc=&store= is similar to your project but they are controlling stepper instead of servo motor.
gadgetng
Postby shahrul » Fri Oct 19, 2012 12:57 pm
Servo Motor use signal 50Hz. PWM module can't generate this low frequency. Then, can use Timer Interrup to generate the pulse. Maybe, interrupt is difficult for beginner.
