dc geared
dc geared
Postby faris » Wed Dec 05, 2012 6:02 pm
hello.i'm intended to purchase a dc geared motor (SPG30E-300K). but first i have a question to ask. is the motor capable of rotating with a 4KG load exerted upon it if i connect it vertically. distance between the shaft and load is approx 5cm.
faris
Re: dc geared
Postby low5545 » Thu Dec 06, 2012 6:26 pm
If the load is 4kg and the distance between the shaft and load is 5cm. We can use torque to measure it. As we know the torque of the motor is 1176mN.m, and that equals to 1.176Nm (SI unit).
Torque= Force x Lever arm
= 40N x 0.05m
= 2 Nm
**4Kg = 40N (W=mg)
Therefore the motor is not capable to accomplish the job. But you can try this motor SPG50-180K http://www.cytron.com.my/viewProduct.php?pcode=SPG50-180K&name=DC%20Geared%20Motor It has 1.96Nm of torque, should be close enough for your project. But it could take in lots of current.
Hope this helps!
low5545
