G15 Cube Servo
Re: G15 Cube Servo
Postby shahrizan1980 » Thu Apr 03, 2014 11:57 am
ober WROTE:
shahrizan1980 WROTE:Hi everyone.
How do i know the G15 still in good condition? Tried everything (setled, reset factory), no response at all. Im using SK40C with PIC16F887
Can help to verify a few things:
- Is the program being loaded to PIC16F887 and it the code is running?
- Is there is power for the G15 and is it sufficient?
A photo of the hardware setup and the sample code you use should be helpful.
Yes, previously the code & cube servo working good. (i got the code for PIC16F887 from cytron website). I ask Idris (cytron staff), he said, the indicator LED will light up for 1 sec, when powered up. That not happen to my cube servo. So yesterday, i send back for warranty. :D hope get back ASAP. Only few days to MiROC
shahrizan1980
Re: G15 Cube Servo
Postby ober » Thu Apr 03, 2014 5:10 pm
Hi, we just received 3 unit of G15. After checking, we notice the voltage regulator is burnt (as shown in the photo). Please check the polarity of power to the G15 Driver (I am assuming you are using G15 driver). Wrong polarity of power will definitely kill G15.
If possible please share the hardware setup, a few clear photos will help us to give advise and prevent similar case to happen in future.
Previous
Return to DC Motor
