G15 Cube Servo
G15 Cube Servo
Postby AGPDL » Mon Dec 10, 2012 10:08 am
Hi All,
I have 4 units of the G15 cube servo. One of them seems to be malfunctioning. It just keeps spinning when power is connected. I have tried to factory reset it but still does not solve the problem. I have managed to confirm that at least the address is set to 0x01 when I do the factory reset. I am not sure if the other registers are also set to their default values.
Does anyone have the full list of factory default values for the G15 registers ?
Thank you
AGPDL
Re: G15 Cube Servo
Postby yonghui » Mon Dec 10, 2012 12:31 pm
if u have the G15 user manual in hand, u can refer to a table in the user manual which list all the control register address and default values.
thanks & regards,
Re: G15 Cube Servo
Postby AGPDL » Mon Dec 10, 2012 2:43 pm
Hi Yonghui,
Thank you Found the list.
Regards,
ag
AGPDL
Re: G15 Cube Servo
Postby low5545 » Mon Dec 10, 2012 3:06 pm
Did the servo LED blink 4 times when you factory reset it?
low5545
Re: G15 Cube Servo
Postby robosang » Mon Dec 10, 2012 6:03 pm
I got 2 pcs 8-) Been working fine out of box.... just the gear sound a bit noisy, but is still fine for me!
Anyway, stop playing it after initial test, busy with other stuff :mrgreen:
Re: G15 Cube Servo
Postby yonghui » Mon Dec 10, 2012 6:12 pm
as mentioned by low5545, the LED on G15 Cube Servo will blink 4 times if the reset factory command is sucessful.
Re: G15 Cube Servo
Postby ubai » Thu Dec 13, 2012 12:01 am
Ive tried using 4 cube servos on one g15 port and failed. but when I tried using 2 servos each on one G15 port. all 4 servos work's fine :geek:
ubai
Re: G15 Cube Servo
Postby zhenning » Thu Dec 13, 2012 12:07 am
ubai WROTE:Ive tried using 4 cube servos on one g15 port and failed. but when I tried using 2 servos each on one G15 port. all 4 servos work's fine :geek:
Maybe not enough power?
zhenning
Re: G15 Cube Servo
Postby robosang » Thu Dec 13, 2012 8:41 am
I have two G15 only, cannot verify that. Anyway, both the terminal on G15 shield are same, so I guess it would the connection between G15. It might the signal or power is not connected properly.
Re: G15 Cube Servo
Postby low5545 » Thu Dec 13, 2012 2:21 pm
Ya, maybe one of the servos has some connection problem. Maybe try to rearrange the order, and try to find out which is faulty.
low5545
