C36R servo
C36R servo
Postby mohd hafiz » Tue Feb 26, 2013 3:55 pm
hello..i want to ask you about servo motor. did C36R servo motor suitable in arm robot project? for my project, i has two movement that need servos. first, for the body movement, to rotate it 90degree clockwise and 90degree CCW from initial position. second is to control gripper 90degree CW and retturn to initial position. is this servo suitable?
lastly, this servo can connect directly to arduino without any additional circuit right?
mohd hafiz
Re: C36R servo
Postby gadgetng » Wed Feb 27, 2013 11:51 am
For the body movement, i don't think C36R can due to torque constraint. Anyway, it depends on the size/weight of your system. Better to use higher torque servo motor.
For gripper, i think it can.
gadgetng
