Speed-Torque Graph
Speed-Torque Graph
Postby vivekregeev » Thu May 09, 2013 6:29 pm
Hello,
i would like to obtain the torque of the motor from its corresponding speed. The motor i have bought is modeled SPG30-300K. Looking at the data sheet they have given the torque-speed graph, however the data sheet says that for this motor model its rated speed is only 12 rpm. The graph on the other hand says its 5200rpm. So im a bit confused. Is the graph for the motor without the gear. All models of this motor are provided with the same graph. Hope you guys can help. Thanks.
Regards
vivekregeev
Re: Speed-Torque Graph
Postby waiweng83 » Mon May 13, 2013 11:54 am
Yup, you are right. The graph is for the motor without gear and the rated speed is after the gear.
waiweng83
